I have a monte carlo instrument cluster that has been redone to carry four 2 1/16 gauges and a 3 1/8 tach and speedometer all autometer ultralites. I also have a 2 gauge center console pod and a 3 gauge a-pillar pod. All gauges have about 500 miles on them.
The gauges I have are all electrical excempt the speedometer
Speedometer $170
Tachometer $80
boost $35
oil pressure $45
oil temp $35
water temp $35
fuel pressure $170
egt $100
air fuel ratio $45
volt meter $35
fuel level meter $30
I can email you pictures if you would like. I will try to post some. Also, I will try to add part numbers later. I will probably be posting them on ebay soon.
Speedometer $170
Tachometer $80
boost $35
oil pressure $45
oil temp $35
water temp $35
fuel pressure $170
egt $100
air fuel ratio $45
volt meter $35
