F foregn2 New Member Joined Oct 28, 2005 May 4, 2006 #1 How do remove the filter to clean or replace without bolting out the WHOLE thing. The foam filter is falling to shreds and off the filter cone. So i want to replace with K&N
S Scott231 Mean Scott Joined Oct 2, 2001 May 4, 2006 #2 Simple answer...you don't. I have the correct 14" K&N filter (used) for that system. $15 shipped to your door.
F foregn2 New Member Joined Oct 28, 2005 May 4, 2006 #4 Scott231 said: Simple answer...you don't. I have the correct 14" K&N filter (used) for that system. $15 shipped to your door. Click to expand... Sent you PM
B BLKBUTY New Member Joined May 1, 2006 May 5, 2006 #5 What is the number of the K&N filter. I have the same unit and would like to replace with a K&N. Thanks, Kevin
S Scott231 Mean Scott Joined Oct 2, 2001 May 8, 2006 #6 It is simply a 14" K&N Cone filter with a 3" inlet. It'll be on the Universal applicatoin page of any K&N catalog.
F foregn2 New Member Joined Oct 28, 2005 May 9, 2006 #7 Scott231 said: Simple answer...you don't. I have the correct 14" K&N filter (used) for that system. $15 shipped to your door. Click to expand... Scott Thanks for the filter got it installed and everything ok. Great Guy to deal with
