The motor mounts are SUPPOSED to hit against the freeze plug boss, and "tweaks" or pulls into that corner. It is kinda like pre-loading it, which keeps it from rattling around under power.
We designed ours the same way. We just made them "tweak" a little less, because our thicker 1/4" base plate will move much less under power. Same idea though, you don't want it to rattle on the drivers side once the motor starts to pull over under power. GM designed it this way, and made the freeze plug bosses strong enough to take the extra load. It gives it a lot more support on the pass side too. I am getting a bright red sticker to put on our mounts to let people know this. You would be surprised how many people see that & wonder.
