Anyone using Ridetech true turn
ersin87
Anyone running Ridetech true turn with there coil overs front and rear and detroit speed muscle bar I'm looking for any info on this setup the car will be used for some drag racing street driving and may look into road track racing my car should be low 11 high 10's if anyone has some input on this set please chime in
I have the Tru turn with coilovers and Ridetech Musclebar HR bar in rear car drives great still cut 1.48 60ft so far Car drives great
front and rear single adjusts , ,
up front...tube uppers , spohn lowers , no front bar
in the rear ...wolfe dbl adjust cmoly rear arms upper and lower ,hrparts rear bar
1.42 9.90 137 on 295/50 -16 drag radials
Sweet6 I think that's the route I will be going
Pace carter what does that setup cost roughly
i think its like 1500 for the coil over shock setup , the rears are around 800 and more han the fronts because of the brackets needed to move the lower shock mounting and the upper mounting brackets made for eye bolt
my setup which went in last spring will probably be up for sale before spring , car has progressed to the point its more of a drag car not concerned about corners so plans are to go back to std springs and dbl adjust.. maybe afcos
