E enforcer1 New Member Joined Nov 24, 2002 Mar 3, 2003 #1 If so, how in the world do you get the magazines apart? The baseplate has a stamped in notch that won't allow the plate to slide off. Whats the secret?
G galoush HWY2HELL Joined Sep 22, 2001 Mar 3, 2003 #2 I belive that the mags are the same as an HK 91 so you might be able to use those .
C ChrisCairns Senior Member Joined May 24, 2001 Mar 3, 2003 #3 Pry up on the end of the floorplate that has the crescent shaped dimple....just enough so the dimple is up enough to slide the plate off.
