Having recently R&R'd that same line, during installation, had to remove the drivers side front tire to get access to the suspension spring. The fuel line runs through that area and it was getting hung up in the spring. Was able to use a long screwdriver to guide it into the correct area and past the spring.
In hindsight it may be an idea to tie a heavy string to the front of the line, and pull that through as the line is removed. Then when re-installing the line, re-tie the string to the front of the line to help guide it back through.
RemoveBeforeFlight
