G gnXfan GNless but Debtfree too! Joined May 24, 2001 Apr 24, 2002 #1 ie, run then adjust, then run again, etc etc etc? just curious - were you happy? did it = good street performance after? _BOB
salvageV6 Daily Driver Joined May 25, 2001 Apr 24, 2002 #2 Yup 3 runs, minor changes in between since they monitor A/F ratio. 24 psi. boost 356hp and 529 ft.lb.s torque. Don't let Zap see this.... Dyno day last Saturday in CT. T&M Corvette, Manchester. Backed off to 23psi. on the street with alky.
B blackbuick87 Senior Member Joined Mar 11, 2002 Apr 24, 2002 #3 Salvage V6 what was the difference between your first and last runs?
salvageV6 Daily Driver Joined May 25, 2001 Apr 24, 2002 #4 They were within 14 hp. but the fuel was better delivered at WOT bumping the f.p. up ended up at 11.1. In the midrange the A/F on spoolup up to 4Krpm was lean at 13.3 and went down to a safer 12.6 or so. Not sure if it would have been noticed as far as power level but the A/F change means much safer on the street. Also I learned a wideband O2 is a neat tool to have. Getting my EGT meter hooked up this weekend should also help.
