Originally posted by jetmech
just make sure when you take everything apart you keep all the shims and put them back exactly where they came from. the pinion bearing will need to be pressed off and the new one pressed on.. Also mark the pinion nut before you loosen it and when you put it back to gether go 1/8 of a turn tighter when put back together. you may want to replace the seal too.
