I just tore down my motor due to excessive blow by. I had the motor rebuilt about 2 years ago. TRW pistons, ported heads, intake, comp cam, TE33 turbo, 3200 stall, Walbro Fuel pump, Headers, Spearco Intercooler, 42.5 lb injectors, TPS enhancer, and many other small goodies. After the rebuild, I could never get the car right on Top end or WOT... After sticking it in the garage for a year I started messing with it. I noticed I was losing water and took the heads off. The gasket was blown and I had a cracked head as well. So I did what every average enthusiast would do, I purchased a set of Champion heads and a fully (cut in half) ported intake. Once I did this, I saw an incrediable amount of blow by. I blew the dip stick right out, I even blew the intake adapter elbow right out of the intake (broke the aluminum bracket holding it to the intake) I had tons of oil in the throttle body (which is now repositioned in the intercooler pipe close to the intake), I tried venting the motor better but had no success. After realizing this much blow by had to be coming from internal, and having my compression gauge show 98 psi in 4 cylinders, I realized I had a ring problem. After tearing down the motor is was clear where the rings failed. Now that I have everything apart, I plan on building the bottom end.. any suggestions?? I was planning on turning the crank (maybe cutting it???), new bearings, billet mains, deburr everything,
enlarge the oil passages, was even going to look for longer rods, however, I haven't read or seen anyone do this.. Any suggestions or advise would greatly be appreciated.. Oh, also, I found a 3" DP for us hot air guys.. I'm working with Brian Weaver of Gbody in getting this cloned. He's got the flanges already made so we may have 3" dp coming soon..
Rod
Rod
