My brother has a '95 9C1 caprice with about 55k miles on it. It occasionally has a crank but no-start condition. The fuel pump went out a couple months ago, and we replaced that and the filter, it seems to be getting fuel. It also does not die once it's started. We also replaced the battery and had the alternator/charging system tested, and they look good.
Oddly enough the body is in mint shape, but the engine area and underbody are rustier than I would expect. Are there any power junctions/grounds/fusible links we should check for corrosion? Any other areas to look at?
Thanks.
Pete
Thanks.
Pete
