Still have a terrible idle. Been following symptoms for a month now and very little success. Started out with a great 2 hour driver to pull in to the driveway to have crank but no start. Noticed the plastic GN emblem on the coil pack had melted and the heat shield clip for the hood just above the coil pack also melted. Changed the Coil Pack and Module. Car turned over but idled awful. Did spark check and everything was ok. Did a fuel check and injector test and all was ok. Adjusted TPS within normal range. Adjusted cam sensor in range. No luck. Had a back up Cam Sensor and Crank Sensor put both in and no change. MAF is functioning. Scan master readings all normal range with no codes. Did a ground check and all fine. Checked all wiring harness wires from module to ECM. Not evident of shorting out. Put a different ECM in with no change. For grins changed plugs and nothing. Buddy has modis diagnostic tool and the car is not throwing any codes, however, not much info will to that from this car. When diagnostic tool set in limp mode the car idles smooth for the 2 minute cycle in limp mode. O2 sensors functioning properly according to tool. Before I go through the pain of towing ut 40 miles to a professional is there anything I am missing? Thanks
