Pronto
Believe nothing you hear and half of what you see.
- Dec 9, 2002
Many people are looking at stock replacement fuel pumps that can supply enough fuel for E85 and big injectors. Some have a higher volume at idle than the regulator and stock return lines can handle. If the return line restrictions are relieved everything is fine. The fuel won't heat up and the pump is not working too hard. In one of Ken's posts he has all the inside diameters of the saginaw fittings, regulator and line fittings with how much improvement the mods will do for flow. I don't see how this is a bad modification to the fuel system. It seems this is getting way over blown.
