I need advice on how to adjust an AMS-500 boost controller on an OEM actuator. Iv'e got it plumbed as per the instuction with the exception that the actuator doesn't have a line diectly from the manifold. I'm using compressed air to simulate the boost pressure for adjusting. I adjusted the stage one to open the actuator at ~15 psi. I set stage 2 to the same setting but when I turn stage two on the actuator closes. I want to adjust stage two to ~25 psi but have no ideas on how do this. Anyone have any ideas?
