The voltage light flickers, so I popped the hood, was looking at the alternator and noticed that the connector behind the alt. is blackened... Is that a problem/hard to replace? Checkers carry um?
See it the contacts got damaged. The connector for the idiot light should not look like that unless the alternator is shorting out. If you wiggle the conector does the problem with the volt light go away?
