Alky kit ? Winter storage
Discussion in 'Alcohol, Nitrous and Propane Tech' started by Nicholas Maiers, Nov 19, 2017.
  1. Nicholas Maiers
    Nicholas Maiers
    Expand Collapse
    May 21, 2017
    102
    3
    Offline
    Good morning guys I recently had market installed and it’s getting to the time of year where we’re going to start getting below freezing temperatures and my car will be stored in a non-climate controlled area so do I need to drain the system and and something like Windshield washer fluid
  2. deezdad
    deezdad
    Expand Collapse
    Mar 25, 2005
    825
    140
    Offline
    Just did this.. I googled winterize alky turbobuick and a thread came up with Julio saying to unscrew nozzle from up pipe, place in container, add -20° f blue washer fluid to reservoir, turn up knob to 8, hit test button till blue fluid comes out. That's basically what it says but search for it so you can see his procedure first hand have a good one
  3. deezdad
    deezdad
    Expand Collapse
    Mar 25, 2005
    825
    140
    Offline
  4. Nicholas Maiers
    Nicholas Maiers
    Expand Collapse
    May 21, 2017
    102
    3
    Offline
    That’s what I thought but wasn’t sure thank you bother
  5. hotairgnx548
    hotairgnx548
    Expand Collapse
    hotairgnx548
    Apr 7, 2010
    409
    24
    Offline
    julio- if car is kept in garage that doesnt see temps below 40 degrees is this still necessary? john
  6. turbojay
    turbojay
    Expand Collapse
    Feb 14, 2009
    651
    53
    Offline
    I've never done anything for storage in a semi-heated garage, alky system still working fine after 6 winters.
  7. No disintegrations
    No disintegrations
    Expand Collapse
    Dec 27, 2015
    660
    50
    Offline
    Straight methanol freezes at an unearthly -65 f. So what's the question?
    • Like Like x 1
  8. Nicholas Maiers
    Nicholas Maiers
    Expand Collapse
    May 21, 2017
    102
    3
    Offline
    Really I did not know that
  9. No disintegrations
    No disintegrations
    Expand Collapse
    Dec 27, 2015
    660
    50
    Offline
    Ya methanol is what gives windshield washer fluid it's antifreeze property. The blue stuff is about half water and half meth for a -20 rating.
  10. Nicholas Maiers
    Nicholas Maiers
    Expand Collapse
    May 21, 2017
    102
    3
    Offline
    Well I’m running vp m1
  11. No disintegrations
    No disintegrations
    Expand Collapse
    Dec 27, 2015
    660
    50
    Offline
    Right, which freezes at negative 65 . Hopefully it doesn't get that cold where you live
  12. Nicholas Maiers
    Nicholas Maiers
    Expand Collapse
    May 21, 2017
    102
    3
    Offline
    Lol I hope not either so it should be fine , is there any reason to drain the pump
  13. Jerryl
    Jerryl
    Expand Collapse
    Doing MORE with LESS!
    Dec 14, 2004
    7,641
    299
    Offline
    The main reason for the system flush before storage is due to the chemical nature of methanol, not because of a freezing concern.
    Methanol will dry out the pump seal if not "circulated" and the pump will end up leaking sooner.
  14. Turbo Keith
    Turbo Keith
    Expand Collapse
    TURBO KEITH
    Sep 16, 2015
    893
    135
    Offline
    If its where you can just start the car maybe weekly and just hit the test button and circulate the Meth , Letting it sit is not good for the pump
Share This Page
