hey all, i was wondering about the difference between alcohol chips and a regular chip. 2 years ago i bought this extreme extender chip for my car and been experiencing leaning problems. i don't know much about how a chip is programed. i have tried almost everything to change the causing problem and no luck. the only thing i have not done is buy an alcohol kit. i was told i didn't really need it and can play around the functions of the chip. first i will tell you my set up--- rebuild stock 3.8 30 over forged pistons, ported stock heads, 3600 stahl multi disc vigi, 65mm tb, 83# siemens, precision fm, gtq 70, custom cam by crower, 3.5ls1 maf, trns +. no alcohol installed. dual in tank pump. i think thats about it. the problem is the car leans out at the top rpm and top of the gears sometimes in the power band. off the line its strong and pulls hard then it takes a dump at around 4000 and up notice my stall. from the egt and direct scan it just goes from rich to super lean. i use 116 octane. this is all at about 25# of boost. when i drop the boost to about 16 the car runs great still and the upper rpm is still lean but not as much. my fuel system seems efficient for my set up. i have checked the the whole fuel system and is great. the second pump kicks in at 10 psi still. it's just by looking at the directscan it's rich and then it takes a dump and drops to like 500 's. and the popping starts and the car falls on it's face. i've even tried taking timing off and playing with the blm still all the results are the same. the only thing i haven't done is install an alcohol set up and use another chip besides the extreme extender. the reason i want to stay with this moded ecm is because the car runs so good on the streets. street ability is a must for me. is the alcohol chip expecting the alcohol spray and and leans it out? i would really like to solve this problem. i've been away from the car for about 1 1/2 years now because i'm in the military and stationed at another country. i can't stop thinking about the car and the problem. i have to figure this out. i was looking around and saw that they have a system now that eliminates the maf. i can't believe that this old car is still growing and getting more sufficient and faster. thank god for the turbo regal!
thanks in advance
abner
thanks in advance
abner
