Scott : Im running a (t) fitting on my car. I totally bypassed the stock boost solinoid. I am running DFI on the car but I had the stock boost contol by-passed before the switch. I ran a line from the turbo to a T fitting. from there one line goes into the car for the bleed valve. Th other side of the T fitting goes into the relief valve then to the turbo. I got to tell you, with the wastegate rod set to just barely go onto the swing arm, boost spike seems to be very minimal. 2 pounds of boost spike im thinking. Its sort of hard to determine because with the relief valve boost comes on very fast and im real busy trying to keep the car staight!!! I hope its not due only the ideal weather, but at a second roll, the car is all over the road !!!! Ive got the relief vale opening at around 10-12 pounds, and im getting 23-25 pounds for full boost.
LOVE THAT BOOST !!!!!!!!
Jeff C
87 T
