Hi guys,
Ok, I'm stuck and need a little help... I have the car running well at all times, except when I start it cold! It will start, but it will stall almost immediately unless I feather the throttle for about 2-3 seconds... When it's really cold, as it is now (20-30 degrees outside), it takes 4-5 seconds...
I've tried increasing the IAC opening for start, increasing the starting fuel, and playing with the AfterStart tables. Nothing has really seemed to help. I believe the IAC is open enough, but there's probably not enough fuel.
If anyone can provide some examples or suggestions about the AfterStart tables, I would really appreciate it!
THANX!
Bryan
THANX!
Bryan
