Aftermarket performance parts
Built 200r4 with billet parts and deep pan with ptc nlu 9.5.1500 pick up.
2.05 Xfi and edash 1350
Bison 6766 turbo 800
Gn1 headers with 38mm tial wg. A couple ugly welds but no leaks 500shipped
Good coil pack and 10mm wires 140 shipped
Accessories bracket with ac delete pulley and power steering pump 120
Aftermarket turbo drain and feed 70 shipped
Racetronix Injector harness 50 shipped
Ported stock intake with egr blocked 290shipped
Lt1 starter 50shipped
70mm doghouse and throttlebody with tps, billet angled iac and billet vac block plus egr block off 350 shipped
Stock fuel rail with kirban regulator and gauge with an-8 fitting 70 shipped
20190904_161053.jpg20190904_160858.jpg20190904_162041.jpg20190904_161934.jpg20190904_161139.jpg20190904_162330.jpg20190904_162158.jpg20190828_204333.jpg20190828_204049.jpg20190829_224350.jpg
It has like 1700 miles. Ck Forward drum, 300m input and output shaft, its dual feed and have the higher line pressure kit from ck. It holds my 9sec power and dont skip a beat.
The drain is the newer version that is easier to get on and off and move around. Feed is stock one but not the factory one
If green eye doesn’t take the turbo drain line. I am second in line. Let me know. Don’t want to step on anyone’s toes.
District heights off of 495 like 5mins away from Redskins stadium. Chesapeake transmission in queensville md not sure at stall dusty spec'd it out but it spooled my 6766 almost instantly and been over 140mph
