Turbo Indian
worlds quickest 6cyl bird
- Sep 25, 2003
aerospace components vacuum pump, baffeled tank & collector tank, bolt on bracket for Buick V6. if you wish to use the serp. pulley you need a small crank pulley to insure not to overspin the vacuum pump. you will most likely need to do some modifications for the belt to work on YOUR set up.
500.00 shipped to lower 48
