I have a adjustable wastegate with the metal piece in middle and 2 bolts on each end that sits in the middle of the wastegate arm. How do you turn the boost up? I've tried turning the screws etc with no increase in boost.
Also when i go WOT from roll bost jumps to about 8-10 lbs then to 15-16 lbs
What is the cause and whats the fix or is it normal turbo lag?
