ITSAV6
It's my Granny's car!
- Nov 13, 2001
At 100 miles or so I crawled underneath looking for oil leak and you could here a faint tap-tap-tap. 25# oil psi hot @ idle and 45-50# cruising @ 50-55 mph. Can't see the crank walking. My machinist listened to it today and said to check it and it shouldn't have more than .009.
If it does he'll be eating it as he set the crank and billet caps so it would be correct
I can pull the crank back and forth with the flexplate if I snatch it. If I pry it back/forth it looks like it is moving more than .009 I cut open the filter and it has no bearing material but the oil in it has golden particles in it. God I don't wanna pull this f---er back out!
