- Aug 1, 2003
And that there is the difference between the inferior(maybe counterfeit) store filters and the superior fleet packaged ones. There is a difference. I'll post pics as soon as I waste $4 on a AutoZone filter.
What I'm saying is, I got my last filter from Ferman Chevrolet in Tampa. It is exactly the same as the one I got from Advance Auto Parts.
They have changed. The top part with the threads used to be convex slightly where the threads were and the metal was heavier and thicker. Now they are completely flat on the top and the threads are different. it works, but it is different.
If you are going to post pics, I think the PF1218 is the most dramatic difference. It's the standard chevy small block filter. I found one of the old ones at an Advance store here in Lakeland and I bought it. I won't buy those new ones...
Okay.Here are some pics comparing my fleet PF52 to the aftermarket PF52. I choose the PF52 since I figured to majority of us are using a stock filter size. I would assume the same applies to the PF1218 and PF48 used on an LSX. First there is a size difference. The fleet PF52 is longer. About 10mm.Diameter is the same.The big difference is on the bottom. The drain back valve on the fleet is black in color. Pink on the aftermarket PF52. The holes appear to be the same size. And as far as I can tell both filter medias are paper. The fleet PF52 has Made In USA printed on the end. Just a number on the aftermarket. The box is printed in the USA though. No idea where the filter is made.And the color of blue is different. Fleet PF52 is a darker blue.I also did a bang the filter on the countertop test and I didn't see any loose paper of media dust particles come out of either one.
While everyone is quick to jump on the all AC is junk reguardless of which one you use bandwagon, I might point out that every brand name has a problem with being counterfeited. Where's the pics of the fake Frams,Wix,Baldwins and Mobils? Maybe the reason is that AC/Delco gives a damn about quality control.If the aftermarket is peddling fake filters than you know they are doing it with everything they can make a quick buck at.
And I did notice that nobody even bothered to mention media size? I also sell a PF1218 size filter that has the synthetic media that makes those Mobils look rather puny as far as filtering capablity. You pay the price for it. Overkill IMO.If your going to start a debate about filters than post up some numbers to support why you pick is superior. It's a filter afterall. Not some accessory hanging off your engine.
And why dont I see any type of magnet. Aint it important to see if your bearings are wearing abnormally? It's a waste of time sending in oil samples or cutting filters apart with out one IMO. BTW I dont cut my filters apart. The magnet is just there to keep what metal there is in my oil filter. I also run a magnetic drain plug. No known metal particles hanging on it either. Either my engine isn't wearing from using Mobil1 oil or maybe my cheap AC filter is doing it's job. Maybe I'm just good at screwing motors together. Who cares?
Pic 1-Size comparison. Fleet PF52 on the right.Aftermarket on the left
Pic 2-Labels. Both appear to use the same labels
Pic 3-Fleet PF52. Made In USA
Pic 4-Aftermarket. Just a number
Pic 5-Bottom side.Fleet PF52 on right.Aftermarket on left
Crap...I've been using the AC filters from AutoZone on my 2005 Silverado since it was new...I have a few at home...I'll cut one open tonight...maybe I got lucky and they aren't the cheap counterfeits...:frown:...luckily I bought
a big stash of the AC Ultraguards before they went discontinued...I use those on my GN and Turbo Regal...
The PF-1218 is the later # for the pf-35 truck filter and they also use to have a shorter version of the SBC filter pf-25 for the car using a sbc.
I used to work @ advance auto for 6 yrs and when i left the ac-delco line of filters and numbers changed.
i'm glad i no longer runa the stock location filter. the turbo savers came with a baldwin filter. I use a hasting filter that i get from my amsoil guy. I was doing some research on the hasting filters and hasting bought out baldwin filters and they are now the same filters.
Engineering Bulletin 98-4
DO NOT BLOCK THE BYPASS No filter will hold up on a cold start, with 20/50 oil even the billet filters. The way the stock buick oiling system works is a poor design. Oil from the pump on does not get bypassed by the pressure regualtor spring in the pump until it goes through the filter.
actually, having the bypass after the filter would make it work just like your fuel system, where the bypass (pressure regulator) is after the injectors.Norbs i believe you are incorrect. The entire reason for the bypass spring is to regulate how much pressure is being sent to the filter to keep from blowing the filter apart.
It would be stupid to have the bypass after the filter.
there's a couple of bypasses, so it's important to know which one is being discussed.
There's the oil filter bypass in the oil pump cover (little black nubbin thing), and the pressure control bypass (spring and piston).
The spring and piston assembly sets the overall pressure. The filter burst pressure needs to be higher than the pressure set by the spring and piston *plus* the differential pressure across the filter. So if you see a cold start pressure of 100 psi, and suppose at cold start there is 50 psi across the filter, then you need a burst pressure of at least 150 psi or boom.
The oil filter bypass sets the differential pressure across the filter (and hoses and engine oil cooler and the oil cooler adapter). The dP (abbreviation for differential pressure) depends on the oil flow rate through the filter, how thick the oil is, how big an oil cooler you have, how big the oil filter is, what kind of oil filter you have (ie paper filter or metal cartridge filter), how big the lines are, and so on.
Blocking the oil filter bypass functional means that when cold, the oil cooler and oil filter have to take the full oil pump flow, and that high flow of thick oil means a high dP. That high dP can deform the oil filter internals (though that Baldwin spec of 100 psid sounds pretty darn stout!), and it will also raise the oil filter inlet pressure, which could lead to a bursting problem.
Leaving the bypass in place reduces both the filter dP and the filter inlet pressure, thus solving both the burst problem and the media crushing problem. Only issue is that unfiltered oil will be fed to the engine on every cold start, and if the filter ever plugs enough to raise the dP when hot (such as when some bearings are going bye-bye, or maybe a blown headgasket dumps a bunch of garbage in the pan), then the engine will get unfiltered oil all the time. My recollection (may be wrong) is that the original PF-47 filter was small enough to cause the bypass to be open at all times, since it has such a high dP even when the engine is warm.
While norbs has apparently had problems with a blocked bypass, mine is blocked and I haven't seen any ill effects yet. I think the key is to reduce the filter dP when cold. As such I recommend:
- big filter (I used to run a PF 1218 I think on my Turbosaver, now I have a System1. If I was buying parts all over again I'd go with a Biggie adapter)
- stock size oil pump gears (lower pump flow than the BBB gears a lot of guys install. If the stock size gears put up enough flow to maintain the desired pressure, all the bigger gears will do is circulate more flow around via the spring and piston bypass)
- thinner oils (I usually run 10W-30 in the summer, trying some 5W-30 right now. Synthetic oil would probably help this out too.)
- not revving the engine until it warms up good (higher rpms = higher oil pump flow. I won't get on it at all until my hot idle pressure drops to 40 psi or less.)
- live somewhere warm (like Texas)
Here's a sketch of the system.
John
at least with it after the filter, all the oil still goes thru the filter, ,which seems like a good design to me. unless the bypass doesn't work and the oil pump is kicking out lots of oil pressure, an oil filter will not explode unless it has a manufacturing defect.
just keep off the gas until the oil gets some heat in it- that's how the Chevy V8 guys do it when they block the bypass on those engines. the only reason they block it off is because GM Powertrain put the bypass BEFORE the filter on those engines back in the 50's for some reason.
