i installed a stand alone harness on the car and i am getting around to wiring the ac. i replaced dryer, compressor, orfice tube, because it had been sitting for a while and compressor locked up. i replaced high pressure switch as well.
Here is the problem, before i take it to the shop to vacuum i wanted to make sure all the wiring was correct, so i turn on the ac on max and without any pressure it engages the clutch i unplug the clutch cycling switch and of course it disengages.
So why is it allowing the compressor to engage with no pressure at all like 5 psi on my cheap guage
i don't want to charge this and it not be cycling the compressor like its suppose to, or not allowing it to disengage at all
