TURBOTIMMER
- Jan 5, 2002
I took my block and pistons to the machine shop after 400 miles of oil blow-by. I checked the ring gaps and everything seems ok there, so I thought there was a problem with piston wall clearance. The guy at the shop tells me there's between .004-.0045" clearance. TRW calls for right around .004". That also seems ok. The problem is that the pistons are rocking in the bores so much, that the rings aren't seating. The only reason I can come up with is that the pistons are expanding enough to grab the pins when they get hot from boost.
I'm I even close here, or do I really not know what the f&%$ I'm talking about? The pin ends looked good when I pulled the motor back apart. Anybody else here ever have a similar problem? Please speak up. I want this thing back together ASAP.
They are TRW forged pistons with the stock heavy pins that come with em.
