forcefed86
- Jul 28, 2005
I know ethanol has a bad tendency to absorb moisture. Ive noticed on cold startups I have a fairly large amount of water coming out of the tail pipes. Enough to leave a large pancake sized puddle on the ground below the exhaust. I run a 3" DP to a magnaflow turbo style muffler and dump in front of aft tire. No catalytic converter etc... Anyone else notice this?
I've also recently had my intake off after a month or so of e85 and I noticed more moisture than I like to see in the lifter valley area. I run one of Erics turbotweak chips and the electric fans do come on earlier than I like them to. (150* or so I think?) I run a 160* thermostat and the car will stay around 160-170 at idle/cruise. (still in the 50/60's here temp wise) Jumps to 180-190 after being run hard. I was thinking a hotter thermo may help evaporate some of the moisture out of the engine, but at the same time I don't like the idea of a hotter themo for when I'm at the drag strip or when the weather starts to get hot.
Think I should go with a 175-180 thermo? Or just buy an adjustable fan switch?
Thanks all...
Thanks all...
