Jackie grabos
- Feb 2, 2011
hello, have a few things wrong with the car and hope someone can help shed some light on problems. I have 87 gn. I was running extender chip, have lucas red stripe injectors, ported heads manifold, hotwire kit after market pump, stock exhaust manifold, te-60 turbo, manual boost controller, caspers volt booster, dutt neck and open pipe exhaust. the car has 65k miles and seemed to be running fine. I installed my scan master and tt chip. my iac was showing 0 and tps at.52. so I started adjusting things and got tps to .44 and wot 4.46 and iac showing about 20. I start the carand does not seem to running as good as before. the car smells crazy rich and now when driving I can hear the turbo spooling at like 1500 rpm or if I blip the throttle can hear it whirl. the car was not doing this before. I could drive and never heard turbo spool until I got around 3000 rpm and would go to boost and pulled strong. car set for 15-16 lbs of boost. chip was made for 16-18 lbs. is this normal or was the way it was running before not normal. car still makes boost around same rpm but does not seem to pull as hard. the only thing I did was adjust the tps approx. 10 times. could a bad shaft seal cause these symptoms. that is the only thing I messed with and iac. looked for leaks and cannot see anything. drove the car about 10-15 minutes and restarted. o2 showed 800's for about 2-3 seconds and back down to around 460. replaced o2 sensor and still the same. the car has never smelled rich until now and very strong smell. tried to adjust fpr and when screw turned all the way to rt fuel pressure is 42. im guessing fpr is bad and have another on order. just to try fpr I got one for a turbo ta to try and see if it would run better. nope, installed and now car is making thud noise from engine bay approx every 10 sec or so give or take a few seconds. I replaced plugs, wires and coil. not going to run car again until new fpr shows up. my vac/boot gauge is showing 15 for the vacuum. took off inlet side of turbo and spins easy, have not noticed anything leaking from car. sorry this is so long, any help much appreciated.
