slimtastic
yea dude...I rock
- Aug 9, 2002
up for sale is a Custom intercooler and intercooler pipes for a Buick Grand National, with included Tial blow off valve
-two massive cores welded together for a total core size of 26x24x3.25
-internal baffleing for proper air distribution through core
-3 inch inlets and outlets
-custom aluminum intercooler pipes with included tial BOV and gm intake air temp provision
-modification of the core support will be required
-will require an external wastegate as the turbo will need to be clocked downward/affecting the stock wastegate angle
650.00
entire front cover/oil pump/cam sensor/water pump/bolts
-complete backup stock cover
-cam sensor works but its got alot of miles/use as a backup?
100.00
custom aluminum racing exhaust for a turbo buick
-single side exit
-custom single muffler
-v band connections so no more broken bolts
-ment to bolt up to terrry houston 3'' downpipe thats been modified for v-bands
-3" construction...its actually not that loud
- entire exhaust weight is about 8-10 lbs
200.00
terry houston 3inch downpipe
-internal gate provision removed for external gate
-wide band bung provision welded in
-v band provision for exhaust
150.00
ive also got a stock oil pan/4.1 production block/ stock rods/ and all the front accessory drives and brackets too if interested
650.00
100.00
-single side exit
200.00
150.00
