A/C VENT QUESTION
Boxcars
Banned
Minor problem -- when I go into any boost, the cold air diverts from the dash vents to the floor, then returns when I've let off the gas pedal. I'm sure this a fairly common problem in our 30 year old cars. Looking for some suggestions of what I might try to prevent this from happening? TIA
You are losing vacuum somewhere, Vacuum leak. Light a cigarette and blow into an associated hose and find the leak. Easy Peasy.
Just dont inhale, that stuff will kill you according to the Surgeon General.
I don't think that will work. You can usually hear vacuum leaks, and I don't hear any. It's more like the boost is cutting off the vacuum somewhere. Maybe my vacuum hoses are not connected to the right connections.
I have the same problem, changed check valve but it still happens. I must still have a leak somewhere
Sent from my XT1254 using Tapatalk
There are 3 check valves I believe - make sure you get the correct one that goes to HVAC.
There's a check valve in the vacuum tank itself also.
Put a T on the line out of it and a vac. gauge on it and see what happens under boost.
Bad check valve?
Now, this sounds like it could be the problem. Which check valve? Would that be the small one normally located behind the alternator? Not sure I have it on, I'll have to check. I've been changing so many things around for so many years, engines in and out, probably incorrect vacuum line re-connections, and so forth, I may have eliminated that check valve. I'm not sure. To the gent who mentioned the vacuum reservoir, just yesterday I installed one because there was none for years. Previously, it would take a minute or two for the dash AC vents to open. Now, with the addition of the reservoir globe, they open up right away when "max" AC is selected, but it didn't take care of the fluctuating air vent problem. I do have a couple more of these reservoirs. First, I'll deal with the check valve, once I know the one referred to, then I'll switch in another reservoir.
The check valve you are looking for looks like this:
It may or may not be faded as this one is. The valve handles the vacuum to the reservoir for the cruise control and HVAC system doors. As for location, check the area behind the EGR solenoid, near the firewall.
RemoveBeforeFlight
RemoveBeforeFlight
I just checked. I knew I had the one pictured, but the small one that sits about 4 or 5" behind the alternator I don't have. I'll put one in there and see if it corrects the problem for me.
That may correct the problem as that vacuum line feeds the HVAC & CC check valve.
RemoveBeforeFlight
