Kent Buckles
BBBAAD 6
- Feb 8, 2002
Hoping someone has some ideas or advice. I have searched through the forums and no luck finding anything that helps at this point. I was hoping to get some input on what else to check or if these symptoms indicate anything specific. Problem: When switching a/c controls from regular to max or when switching fan control from medium high to high speed, i am not feeling or hearing any change in the amount of air coming out of the vents. At this point, air blows cold, blows from correct vents just no change as stated. I have checked for vacuum leaks under the hood, have checked water control valve, checked vacuum reserve "ball", and have checked the heater/ac vacuum controlled door behind glovebox. Have found no issues in these areas as of yet. Any ideas great appreciated.
