The compressor on my 86 GN does not go on unless I jiggle the connector going to the Low Pressure Switch (Pressure Cycling Switch) on the accumulator. I tried to bend the male prongs out a little on the switch attached to the accumulator and I also tried to bend the female prongs in the harness that attaches to it. It works for about 5 minutes (The compressor goes on) but then turns off again after driving a few miles. Jiggling or disconnecting and reconnecting the harness turns it back on momentarily but the compressor shuts off again after a few miles of driving. I tested the freon level and it is correct. I assume I have a bad pressure switch or harness/connector. I know that A/C Delco makes the low pressure switch that attaches to the accumulator. However, does anyone know where I can get a NOS harness or aftermarket harness that looks stock? I would like to replace both but cant find the harness.
Also, I have noticed that some of the photos in the service manual (SEE Page 8A-201-17 of the GM Service Manual) show the harness (female) as being the pressure cycling switch. It actually has an arrow pointing to the harness instead of the switch attached to the accumulator. Am I correct in assuming that the arrow in the manual was supposed to be pointing to the switch (male prongs) on the accumulator as opposed to the harness that connects to the male prongs? In essence, I want to know if the harness is the pressure cylcling switch or if the pressure cycling switch is located on the accumulator.
Finally, is there a way to tell if it's the harness that's bad or the switch? I know people talk about "jumping" connections but I dont know exactly how to do it. Any basic articles on this for a novice? Thanks for the help.
