8 87T New Member Joined Sep 21, 2001 Jul 25, 2002 #1 I know that when you go to W.O.T. the ECM will disengage the compresser clutch are there any other built in features that will do the same thing ?????
T Turbo Brian What do I type here? Joined May 24, 2001 Jul 26, 2002 #2 If you have too low a charge, the pressure cycling switch will cause the compressor not to engage.
S scottyb Spongebob Squarecar Joined Oct 12, 2001 Jul 26, 2002 #3 Along similar lines, does the computer shut off the high speed rad fan at a certain speed?
