i did some research here and i couldnt really find the answer. Before i start throwing parts at this, do both of these things not working have a correlation? This is a touch screen (i guess thats what you call it) a/c on an 86 t type. The screen works, the fan blows just hot air. The thermostat was changed to a 160. The chip is a stock chip. I am under the impression that even with the stock chip, the fans should turn on when i turn the a/c on. I checked the hi and lo relays with known good ones and nothing. I have disconnected the delay relay. There is no power going to the fans. I have not checked the power at the compressor yet. Which wire should i check to see if the compressor is getting power? All sensors are connected at the manifold. Any help will be appreciated.
