wlaukaitis
3rd Member
- Aug 5, 2003
Yes, if you had a standard SBC with 2.02" intake valves and decided to change to 4 valve (or 2 intake vs. 1 intake) with 2 1.01" valves, you would end up with .25" more surface area even though the valves are half the size.
Ever wonder whay the intake valve is bigger? I thougt so! Take a piece of paper (which is your intake charge) and crumple it up, see how much volume it has? Now burn it, now see how much volume it has now? There is less "stuff" after it is burned. Keep in mind that gas IC engines are very innefficient.
