347
stock block
eagle forged crank
h beam rods
Custom Bennet hyd. roller 228/238 550 lift
Victor junior intake
Victor Junior Heads
Race demon 750 carb
1.6 rockers
z style t-5
moser 31 spline rear end with auburn pro locker
pro stars converted to 5 lug
.373 FMS gears
Corbeau race seats
8 point cage with swing out bars
spec stage 1 with billet flywheel
grey interior
mickey thompson et radials
new front runners
k member and a arms with coil over kit..
DSS girdle(main support)
New M/T 275 60 15 Drag radials
Canton pan
New Hurst gold shifter
msd ignition with a 2 step(clutch activated)
msd distributer
long tubes,h pipe
magnaflow cat back
subframe connectors
prostars are BRAND NEW
aluminum driveshaft
driveshaft loop
rear end girdle
line lock
3 core radiator w/electric fan
UPR Caster camber plates
Moroso battery box(trunk mounted)
90/10 struts(koni)
Brand new Strange 31 spline axles w/ c clip elims
drilled front rotors
brand new drums in the back
50/50 Drag shocks
Flaming river steering shaft
Firewall clutch adjuster
UPR caster/camber plates
Fresh zaino...
motor was assembled and built by bennett racing and has about 6.5 to 7 hours on it total. email for pics. danbeard35071@yahoo.com
looking for TB or late model truck, sportbike for trade.
stock block
eagle forged crank
h beam rods
Victor Junior Heads
Race demon 750 carb
1.6 rockers
z style t-5
.373 FMS gears
Corbeau race seats
grey interior
new front runners
Canton pan
msd distributer
long tubes,h pipe
magnaflow cat back
subframe connectors
aluminum driveshaft
driveshaft loop
rear end girdle
line lock
90/10 struts(koni)
50/50 Drag shocks
Fresh zaino...
