This car is for sale
VIN:4E3CT64U8LE106202
78,000 miles
5-speed
Plum/Grey
Engine bay detailed and block/manifolds painted
New water pump
New timing belt and tensioner
New accesory belts
All emmissions removed
MLS head gasket
ARP head Studs
All new upper gaskets/seals
Black ceramic coated turbo and manifold/ O2 housing
Optima Red top battery
Limited Slip rear
Good paint
Clear title
everything works inside and out that i can tell
The story is this car was put into a ditch in Aug. 96, and parked. It bent the suspension up and ripped the exhaust off. I picked it up 2 months ago, and replaced both subframes, rebuilt the head and put all new stuff on it. The trans shifts very good with no grinding, good syncros. Also the car has no rust on it anywhere that i can find, it is cherry. On the body, one trim peice in front of the passenger rear wheel is missing from the accident as well, otherwise all lights work, drives good, and has really good power.
This comes with a 92 GSX shell i have and every DSM part i can find around here as well, if you want it. 3 of the original Talon rims, one is bent. Car has the rims off the Eclipse on it at the moment, but also will include the 17" rims along with it.
Only things needed are an alignment, exhaust, and tires for the 17" rims
First person with $3200 can come get it, if you think thats too much, give me an offer. It runs and drives very well. My number is 804-731-5691, call anytime, car is located on MN/ND border.
I will post up pics tomorrow as the net is really slow tonight, LMK if your interested.
Gary
78,000 miles
5-speed
Plum/Grey
New water pump
New accesory belts
MLS head gasket
ARP head Studs
Limited Slip rear
Good paint
Clear title
Gary
