1.complete 9 inch rear end for g body. comes with strange pro iron center section. 350 ring and pinion. 33 spline /spool. center section bought complete from strange .1350 yoke 33 spline pro race axles . big ford ends .double adjustable upper and lower control arms. strange brake caliper brackets .5/8 wheel studs. 1600.00
2.brand new borg warner sx430 82 mm turbo. 88/96 turbine. 1.58 ar housing. forged milled billet wheel. just done by reed at work turbo. just changed directions on combo 2 weeks old .only out of box for pics. the latest and greatest race cover etc . 2000.00 comes with aluminum down pipe flange and clamp
3.120 lb holley fuel injectors great shape 350.00
4.qa1 g body control arm braces nice.g body 100.00
5. coil springs rear g body 2 inch lower height 75.00
6. billet specialties street lites 15x10 5.5 backspace 5/ 4.75 bolt space g.m. has spacers in them for 5/8 studs. has clearance done above spacers for 5/8 lugs look close at pics 200.00
7. regal grand national trunk/decklid trim nice shape 50.00
8.davis driveshaft speed sensor and magnet 8 mag collar . never used 250.00. collar for 1.812 size yoke
9.A1000 fuel pump nice shape 150.00
10.auto meter sport comp tach with shift lite comes with roll bar mount 200.00
11.auto meter pro comp water / oil pressure gauges 40.00 each 2 1/16 size
12. strange 1027 5/8 stud kit new 50.00
13. frozen boost water to air intercooler. type 12. water fittings upgraded to 1.25 350.00
