1987 REGAL T-TYPE Asking 9,000$
Extremely Clean, Lightly modified street Car.
The time has come to let my 87 T-Type go, so here is your opportunity to own a very clean 1987 Buick Regal T-type. This car is has been driven by an adult female for the first 96K until I purchased it 2 years ago. Hopefully it will get into the hands of a true Buick enthusiast who will take care of it as I have. Through out the 2-year period I have tried to restore this car and also added bolt on modifications that have improved drivability and performance. Car has been garage kept, both by me and the previous owner
COLOR – WHITE
2 OWNERS………………100,600 MILES.
APPROXIMATELY 6K MILES ON THE CAR SINCE ENGINE WAS MODIFIED/REBUILT/REPLACED.
THE CAR IS LOCATED IN AUSTIN, TX., A SOUTHERN CAR WITH NO RUST.
SOME OF THE CARS OPTIONS:
STANDARD CLIMATE CONTROL (IN PERFECT WORKING ORDER, AC BLOWS ICE COLD WITH ORIGINAL R-12 FREON)
POWER ANTENNA (REPLACED/REBUILT)
POWER 6 WAY BUCKET (CONVERTED FROM STANDARD)
FACTORY CRUISE CONTROL
TILT COLUMN
STANDARD MIRRORS
POSI REAR
BLACKOUT TRIM
POWER WINDOWS / POWER LOCKS
ENGINE:
REBUILT SHORT BLOCK WITH STOCK PORTED HEADS
REBUILT STOCK PORTED TURBO
ASSEMBLED WITH SINGLE STEEL SHIM GASKET WITH SILICONE (FOR MORE COMP)
NEW ROD AND MAIN BEARINGS
NEW RINGS
POLISHED PISTON TOPS
POLISHED VALVES, FACE AND STEM
NEW ADJUSTABLE PUSHRODS SET AT .030 PRELOAD
BLUEPRINTED/REBUILT OIL PUMP
ADJUSTABLE WASTEGATE ACTUATOR
NEW AC-DELCO WASTEGATE VACUUM HARNESS
NEW HEAVY DUTY INTERCOOLER COUPLINGS & STAINLESS CLAMPS
NEW GREEN STRIPE 33lb INJECTORS
NEW ATR ADJUSTABLE FUEL PRESSURE REGULATOR
NEW SPARK PLUG WIRES (STOCK)
NEW AC-DELCO SPARK PLUGS
NEW AC-DELCO BATTERY
NEW MODINE ULTRA 2000 HIGH FLOW RADIATOR
NEW FELPRO FRONT/REAR MAIN SEALS (NEOPRENE)
NEW TIMING CHAIN / GEARS
NEW TIMING CHAIN TENSIONER, SPRING, AND CAM BUTTON
NEW BILLET ALUMINUM THERMOSTAT HOUSING & 160 DEGREE STAT.
NEW RJC POWER PLATE
NEW TINMAN CLONE COLDAIR KIT AND STOCK FILTER
NEW 3” MAF WITH TRANSLATOR
NEW FUEL FILTER (AC-DELCO)
ORIGINAL GM, AC-DELCO HOOD LINER
NEW AC-DELCO MOTOR MOUNTS
MINT INTERCOOLER AND SCOOP
NEW SENSORS: OXY, MAF, AND MAT
EXHAUST:
NEW ATR 3” CROSSFLOW STAINLESS SYSTEM
NEW ATR STAINLESS DRIVERS HEADER
NEW ATR STAINLESS CROSSOVER PIPE
NEW ATR STAINLESS STOCK REPLACEMENT DOWNPIPE
NEW ATR 3” PERFORMANCE CAT
(THE ONLY STOCK EXHAUST PART IS THE PASSENGER HEADER)
TRANSMISSION:
BRF - 200 R4
HEAVY DUTY STOCK TORQUE CONVERTER
NEW TCC SOLENOID
LEVEL 10 SHIFT RE-PROGRAMMING KIT
NEW FILTER AND SYNTHETIC FLUID
REAR:
ORIGINAL 8.5” GM LIMITED SLIP, POSI REAR W/3.42 GEARS
NEW REAR BILSTIEN SHOCKS
FRESH REAR GEAR OIL CHANGE
FRONT SUSPENSION:
NEW FRONT BILSTIEN SHOCKS
BRAKES:
REBUILT POWERMASTER BOOSTER.
MAJOR CHAIN BRAKE JOB PRIOR TO MY OWNERSHIP
WHEELS/TIRES:
SET OF (4) FACTORY T-TYPE WHEELS
NICE CENTERCAPS WITH CUSTOM POWER 6 LOGO DECAL
NEW GOODYEAR 235/60 15 EAGLE (FRONT)
NEW GOODYEAR 245/60 15 WINGFOOT (REAR)
INTERIOR:
NEW HEADLINER.
SUN VISORS RECOVERED
TINTED WINDOWS
JVC MP3 RECEIVER ADDED, ALSO HAVE ORIGINAL CASSETTE PLAYER
JVC 12 DISK MP3 CHANGER ADDED (TRUNK)
ATR 2 GAUGE CONSOLE POD
NEW APC COOLANT TEMP GAUGE AND MECHANICAL 1.5 BAR, 22.5lb, VACUUM/BOOST GAUGE
CUSTOM CHIP/ECU/PERFORMANCE FEATURES:
PROPANE INJECTION
CUSTOM UNDER DASH BOOST FEEDBACK ELECTRONICS
NEW CASPER’S GM INTANK FUEL PUMP
CUSTOM FUEL PUMP HOTWIRE KIT
CUSTOM VARIABLE TIMING CHIP WITH LOTS OF SPECIAL EDITS
REMOTE MOUNTED EEPROM, DOES NOT NEED CARRIER
DIRECT SCAN INCLUDED
COMPAQ ARMADA 6500 LAPTOP FOR VIEWING DIRECT SCAN WITH EDITING/BURNING
SOFTWARE AND A CHIP LIBRARY
THINGS THAT COULD BE REPLACED:
WINDOW FELTS BOTH DOORS
REAR BUMPER FILLERS
COMPLETE ORIGINAL MOTOR INCLUDING TURBO AVAILABLE AT ADDITIONAL COST:
HAS A REAL SPARE ON A GN WHEEL:
I ALSO HAVE MANY PARTS THAT WILL GO WITH THE CAR LIKE:
COMPLETE REBUILT POWER MASTER
2 USED CAMS ONE WITH LIFTERS
MAF BOUGHT NEW JUST BEFORE THEY WERE DISCONTINUED AND USED LESS THAN A YEAR
TOO MUCH TO LIST, 12 YEARS OF PARTS I HAVE COLLECTED
Vehicle Condition
Vehicle has a Clean Tx.” title, No liens.
This car is in excellent condition. It runs and drives as if it were brand new in 1987. You cannot build this car cheaper.
If you would like pictures of any part of the car please e-mail me and let me know and I will send them via e-mail
I am happy to answer any and all questions about the car, please e-mail bbucca@gte.net or call me at (512) 863-0478. Leave a detailed message with your phone number & the best time to contact you.
Will be here for a while then moved to e-bay
Brad
COLOR – WHITE
TILT COLUMN
STANDARD MIRRORS
POSI REAR
BLACKOUT TRIM
ENGINE:
NEW RINGS
NEW RJC POWER PLATE
EXHAUST:
TRANSMISSION:
BRF - 200 R4
NEW TCC SOLENOID
REAR:
FRONT SUSPENSION:
BRAKES:
WHEELS/TIRES:
INTERIOR:
NEW HEADLINER.
TINTED WINDOWS
PROPANE INJECTION
REAR BUMPER FILLERS
Vehicle Condition
Brad
