87 T $5,800
y26
74,443 mile on the body
Adj regulator,
Jay Jackson modified TB & Plenum,
Big mouth cold air,
3 inch DP, 3inch cat, bought in 03 and Hooker exhaust less then a yr old.
ScanMaster 2.1,
Boost, fuel, and oil pressure gauge, Deltagate with boost control,
walbro pump with hot wire,
Ported heads, new valves and guides
Pats 2800 converter.
204/214cam,
42lbs injectors,
Stock turbo, IC.
Reman - pass and driver side manifolds 2003
new shocks
Tranny rebuilt with PTS Extreme Deluxe rebuild kit with Alto wide band.
Rebuilt motor bore .30 over Only 3000 miles on both rebuilds.
Main stud kit.
Speedpro forged pistons
93 chip by turbo tweak
recored radiator
driver side polly mount
High Vol timing cover
new oil pan
bilstein shocks
Body is in pretty good shape. Few dinks and a rust spot above driver side T emblem. Bottom part of inside doors are rusting but have not fully shown through the outside.
Inside carpets is in rough shape and headliner sags.
Problems: It leaks oil. Leaks off the front frame probably about 2 - 3 drops about the size of a quarter???? maybe??? No garage or time to look for the problem. Driver side door needs new bushing. Pass side shuts great.
Overall runs strong. Car even chirps second gear. I have not been to the track so i have no idea how fast it goes.. I really drove this thing easy.
I probably have a few parts here that can go with it to.
I hope i did not get to wordy but i can answer your question any time. E-mail me drttyp@comcast.net I also have pics.
I've also been a NEBRA DIGEST member for a while. So i'm not that much of a newbie.
I have to change my info on this thing. I'm located in massachusetts. 30 min from providence RI and 45 min from Boston.
Like too look at the car
I am interested and I would like to come out and see the car. I live in Fall River ,where are you located? Let me know asap so I can take a look at it. or call me 508-676-6791 Jon
I'm sorry everyone i got really busy at work and kind of had to put this a side. To make it easy for me anyone who wants pics please e-mail me at drttype@comcast.net and i will reply with pics. It is a busy time at work right now and i go a few days if not a week with out checking this board. SO best thing is e-mail me and i'll repond with pics.
Thanks again
Steve
