I have some medical bills starting to pile up so I need to get ride of some of my toys and maybe trying to get something else later this winter or spring. This car is great, looks great and is balls out fast with the turbo kicked in.
Send me an email or call me 515-964-2409
jayrj33s@yahoo.com
Jay
EDIT: car now has stock wheels on it.
1987 Buick Grand National
Short Block:
Stock Buick 3.8L SFI Turbo (40K mile GM crate engine)
Stock camshaft, lifters, and timing chain
High-volume high-pressure oil pump
Heads:
Stock port matched
1.77” 1.50” SS Manley valves
Crower 80lb valve springs
Stock head gaskets with TTY bolts
Intake:
Stock lower
Stock ported 62mm throttle body
Stock ported upper intake and with EGR tower removed
Throttle body coolant lines blocked
Induction system:
TE-51 turbo w/.63 PTE exhaust and polished compressor housing
Charged Air Systems V4 stretch stock location intercooler
High Boost Adjustable waste gate actuator
3" BGC chrome MAF pipe
LS1 3.5" MAF Sensor with Translator
9” K&N with 3.5" inlet air filter
K&N valve cover breathers
Chrome up-pipe with sneeze valve
Chrome turbo cover
ATR Cyclops air dam
Fuel system:
Walbro GSS 340m in tank fuel pump
Casper Electronics fuel pump hot wire
Accufab billet aluminum fuel pressure regulator
MSD 50lb fuel injectors
SMC Enterprises dual nozzle alcohol injection
Ignition system:
Stock DIS
8mm Accel plug wires
AC CR-43TS spark plugs gapped 0.035”
Exhaust system:
Stock ceramic-coated headers
Terry Houston 3” down pipe
3” test pipe with dump tube
ATR Stainless Steel 2 ½” dual exhaust
ATR 2 ½” aluminized Pit Bull Mufflers
Cooling system:
Stock radiator
Stock cooling fan with resistor by-passed
160 thermostat
B&M transmission cooler
Transmission:
BRF TH200R-4
Stock D5 torque converter
Hardened stator
Stock clutches with extra clutch
B&M Transpak
Suspension:
Stock 8.5 w/3.42 gears rear end
Air bags in rear coils
ATR Pinion snubber
Poly front sway bar bushings and end links
Stock GN wheels
235/60/15 BFG radial T/A
Body:
Energy Suspension poly body bushings
GM Front frame braces
BGC Rear seat braces
Jay’s GN Front fender braces
Engine Management:
Stock ECM
BstC Boost Command in-car boost controller
Extender Chip
Tuning and monitoring equipment:
Scanmaster II scan tool
Sun mini tach
VDO 30lb boost gauge
VDO oil pressure gauge
VDO temperature gauge
VDO voltage gauge
http://www.mustangmods.com/data/14993/gnengine3.jpg
http://www.mustangmods.com/data/14993/gn5.jpg
http://www.mustangmods.com/data/14993/gn4.jpg
http://www.mustangmods.com/data/14993/gn3.jpg
http://www.mustangmods.com/data/14993/gn2.jpg
http://www.mustangmods.com/data/14993/daver.jpg
http://www.mustangmods.com/data/14993/gn1.jpg
jayrj33s@yahoo.com
Jay
Short Block:
Heads:
Stock port matched
Intake:
Stock lower
Induction system:
Chrome turbo cover
ATR Cyclops air dam
Fuel system:
Ignition system:
Stock DIS
Exhaust system:
Cooling system:
Stock radiator
160 thermostat
Transmission:
BRF TH200R-4
Hardened stator
B&M Transpak
Suspension:
ATR Pinion snubber
Stock GN wheels
Body:
Engine Management:
Stock ECM
Extender Chip
Sun mini tach
VDO voltage gauge
