X-FORD MAN
- May 26, 2001
1987 Grand National with 46,400+ mi. on the body, gets 17 mpg on the hwy, and you can drive in traffic with no issues. You can drive down to a decent hooking track, run some 8's, and drive home. This car has been in car shows with excellent results, trophies and cash winnings. Most of this car was professionally built by Behind Bars Race Cars in IL. $42,000 and shipping to west coast port included. call (808) 554-3669 or (808) 683-0522 E-mail me for pics at underpressureracing@hawaiiantel.net Thank You!
377ci. Motown block
3.48" Eagle 4340 crank
6" Eagle H-Beam rods
Wiseco 20cc dish pistons
CompCams solid roller
Port matched Brodix Track 1 heads 2.08 stainless intake/1.6 inconel exhaust
Super Victor converted to EFI
Accufab 90mm polished throttle body
96# injectors
BBRC custom plenum
Twin 66mm turbos from Limit Engineering
BBRC custom stainless steel headers
Twin ATR wastegates
Tial blow off valve
Innovative electronic boost controller
CAS huge front mount intercooler 6" thick
Dual SX fuel pumps with dual billet filters with 50 micron ss mesh
-10 feed line and -8 return all braided lines
Aeromotive fuel regulator
FAST sequential system with wide band
FAST data logger
MSD digital 7 ignition box
MSD crank trigger
MSD distributor
MSD HVC coil
Turbo 400 with 2.66 first gear, trans brake, reverse manual valve body
Coan 10" steel stator convertor
Denny's Nitrous Ready driveshaft
Chassis Works FAB 9" housing
Strange Engineering third member with 3.70:1 gearing, spool, aluminum pinion support.
Strange 35 spline axles with 5/8" wheel studs
Wilwood disc brakes on all four corners
Wilwood master cylinder
BBRC chromemoly 12 point roll cage with swing-outs
Frame is "X" braced with chromemoly
Chassis Works ladder bars
Chassis Works wheelie bars
Chassis Works anti-roll bar
Koni adjustable shocks on all four corners
2" front drop spindle
Simpson Skyjacker parachute
Centerline Convo Pro rims
Mickey Thompson Drag Radials 295/65 R-15 and MT's front runners
Mini tub in the back
Charged Air Systems aluminum radiator
Dual electric fans
Meziere electric water pump
Borla XR-1 mufflers
12 gallon aluminum fuel cell
I could go on and on with this list, just call if you're serious. Thanks!
377ci. Motown block
96# injectors
BBRC custom plenum
Twin ATR wastegates
Tial blow off valve
FAST data logger
MSD crank trigger
MSD distributor
MSD HVC coil
Dual electric fans
Borla XR-1 mufflers
