87 GN T-Top 55k miles - Iowa - $9700
Crazy D
Resident Madcap
1987 Buick Grand National For Sale
T-Tops
55k miles
PW/PL/Twilight Sentinel/Tilt/Cruise/AC
Pioneer CD deck, but I have a stock GM deck laying around if you prefer
Stock block 3.8 Turbo
Numerous upgrades (see below)
$9700
maddhatter@mchsi.com
This is an almost complete list of upgrades and maintenance since I've owned the car:
spark plugs and wires at 48,000
walbro 340 fuel pump, accufab regulator, fp gauge, new fuel filter
hooker 2.5" exhaust w/ test pipe
passenger valve cover breather bypass
new PCV
underhood, rear, and front body braces
KYB shocks and Variable Springs put on back at 49,500
engine tie-down strap
solid MAF pipe
vacuum brake conversion (the original powermasters are terrible and $$$)
outlaw rims (a couple were pre-roughed up) and BFG 275's put on at 49,500
passenger side header crack welded (this happens on ALL TRs)
tranny and rear end service at 49,700 A-pillar pod w/ boost gauge,
air/fuel gauge
009 injectors at 50,150
TE-44 turbo, ATR 2.5" downpipe, ported elbow at 50,180
Duttweiler neck intercooler
sagging headliner repaired
2800 torque converter
B&M shift kit
brake line lock
larger tranny cooler installed *currently bypassed, stock unit used*
driveshaft safety loop
extra vacuum canister installed
a/c converted/recharged at 52,000
broken power antenna replaced with fixed mast at 52,300
MAF Translator+, LS1 MAF, and Extender chip combo installed at 52,300
New K&N cone filter at 52,300
New 02 sensor just put in
Oil changes done regularly (never more than 2000 miles)
I will include a Turbolink 2.13 disk, and the ALDL cable. May include the 166MHZ Windows laptop if someone would want it.
As far as what's wrong with it... nothing mechanically as far as I know. It's been reliable and relatively economical for 7 years. The body and paint is what a reasonable person would expect from a 17 year old car. Car looks nice from a distance, get many comments, up close it shows it's age in spots. The worst thing outside is a small ding in the passenger side door and a bent up wheel molding. Interior is clean, driver's seat upholstery is starting to split in the middle. Despite these, the car gets comments and looks everywhere it goes, but I feel in the hands of an enthusiast, with a little body work and maybe new paint, this would as good as it gets on the street. The car has the parts to run 11's in the hands of a good tuner.
The plate is photoshopped. :)
For some reason I left the hood open here.
Also give me a phone number I will be able to come look at the car this weekend if that works for you....Have cash on hand no tire kicker here
I've attached some add'l pics (all taken in an "unclean" state, but oh well), including ones of the blemishes mentioned above. I tried to get a pic of the ding in the passenger door and it won't show on camera. I can get pics of anything specific upon request.
So Dave
I need to get a contact number from you.And also to find out if this weekend is going to work out to come and see the car.I would think sunday would be the best for me and my friend. I Need to know because I need to plan ahead.Thanks
P/M me your Info if you don't want to post it here...
The car is still for sale. I'm not big on negotiations, so I'm going to state my bottom line firm price: $9000.
