87 GN for sale or trade
87TIGN
Death by boost
$23,000 OBO I have an immaculate fully built 1987 Buick Grand National with only 85,000 original chassis miles and about 2-3000 on the new engine tranny setup. I have owned this vehicle since January 2006 and when I bought it, it was in pretty rough condition. The engine was pretty beat up and the tranny was in bad shape as well as the rear end and exterior. Over the last 4.5 years I have put about $27,000 into it in parts, machine work and labor only NOT including the original buying cost of the vehicle. I know this is a lot of money to ask for a car in these hard times but once you see the car you will understand why I am asking so much (the price is slightly negotiable). I know this car inside and out and can walk you through the entire vehicle and all the upgrades. I have receipts to prove everything I have put into the tranny and engine and they come with the car (all machine work was done at U.S. Automotive Performance by Jeff, if you know them you also know how good they are). I will list all of the upgrades that I can think of following this posting and if you have any questions please don't hesitate to ask. I am currently on my honeymoon and will be back in town by Monday the 26th, and I will post pictures at this time. The car does leak a small amount of oil due to the racing girdle that is on the car, it is very rare to find a car with a girdle that dosent leak a small amount of oil :). I would be interested in trades and I am really only looking for an 02, 03, 04 Chevy Corvette Z06 with lower miles (60k or lower), I am NOT interested in any MOPAR, Chrysler or Ford products however. Let me know if you have any questions. SERIOUS INQUIRES ONLY PLEASE.
Engine:
Rebuilt at 82,000 miles
- RJC deep sump 7 qt race pan
- RJC engine girdle with crank scraper
- Stock oil pump with spacer
- Polyurethane motor mounts
- Stock crank, 0.020” over (magnafluxed)
- Clevite main bearings
- Stock crank caps, machined to fit girdle
- Stock rods, 0.020” over (magnafluxed, shot penned)
- Clevite rod bearings, 0.020” over
- Stock block, linehoned, punched 0.030” over (magnafluxed, deck surfaced)
- TRW speed pro forged aluminum pistons, 0.040” over (8.5:1 compression ratio [?])
- Stock iron heads (fully ported and polished)
o Intake bowls ported (unsure of size at this time)
o Titanium valve seats
o Titanium intake and exhaust valves
o New valve seals
o Port matched to intake manifold
o Port matched to exhaust manifold
o Machined for beehive springs
o All new spring hard wear
- Comp cam roller camshaft (I believe 0.516”/0.516” lift 210/215 duration)
- Comp cam roller lifters
- Comp cam roller pushrods
- Stock stamped steel rockers
- Comp cam beehive double springs
- Stock intake manifold, port matched
- 60 lb mototron injectors
- Stock fuel rail
- RJC plenum spacer
- Stock plenum
- Stock throttle body
- New coil pack
- New ignition module
- MSD 8.5mm plug wires
- AC Delco CR42TS plugs
- PTE60 turbo with TA49 exhaust housing
o Sleeve bearings
o Stock waste gate
o RJC boost controller
- 3” TA performance down pipe, and cut out
- RJC full front mount intercooler with piping
- Full 3” big mouth fender well intake
- New stock MAF
- Stock radiator
- Stock accessories and pulleys
- 160 degree thermostat
- New IAC valve
- New TPS sensor
- New coolant temp sensor
- New crank sensor
- Stock cam sensor, with prong replacement
- Stock front cover, with stock oil pump
- New IAT sensor
- New knock sensor
- New ’87 Monte Carlo brake booster
- New ’87 Monte Carlo brake reservoir
- Used ’87 Monte Carlo brake pedal set-up
- New Delco oxygen sensor
- New Casper’s engine wiring harness
- Stock exhaust manifolds and cross over pipe, fully ported
- Hooker 2.5” cat-back exhaust
- New power steering pump hoses (hard and soft lines)
- New AC compressor (R134 retro, not charged)
- New AC receiver dryer (system not charged, but closed to keep moisture out)
- Razor alky injection system
- New stock ECM
- Turbo Tweak Alky chip
- New REMflex exhaust gaskets (manifolds and turbo)
- RJC bulletproof head gasket
- All bolts and studs are ARP (rods, main caps, heads, etc.)
- Newer Valvoline full synthetic brake flush
- Oil changed every 1,500 miles, using Valvoline conventional 10W30
- New water pump
- All new gaskets and seals
- Billet adj FP regulator
- Walbro 340 LPH fuel pump with hotwire kit
Transmission:
- TH200R4 transmission
- Fully rebuilt at 82,000 miles
- Pat’s 3000 stall converter
- Brand new clutch packs
- B&M shift kit
- New oil filter
- All new seals
- Driveshaft safety loop
Rear-end:
- Fresh fluid at 83,000 with LSD additive
- Ring and pinion set up shows minimal wear
Suspension:
- Stock front control arms
- Stock springs
- All new upper and lower ball joints
- All new energy suspension polyurethane bushings
- All 4 shocks replaced at 80,000 miles
- Edelbrock adjustable upper trailing arms
- Edelbrock boxed lower trailing arms
- New 17” Crager soft 8 wheels (black)
- New Pirelli P-Zero Nero tires (less than 500 miles)
- Aligned 2,000 miles ago
Interior:
- Mostly stock interior
- Panasonic CD player (I have original tape deck)
- All new speakers, wired to 700 watt Pioneer amp
- Small cigarette burn on driver seat and rear passenger seat (from previous owner, I am not a smoker, and the car doesn’t smell like smoke)
- Head liner fabric may need re-gluing
- Scan master 2.4 PAC alky control box
- 3 gauge a-pillar cluster (all gauges are Autometer Phantom series)
o Water temperature 100-250 degrees F
o Boost 0-20” Hg, 0-30 PSI
o Oil pressure 0-80 PSI
- Center console gauge pod (all gauges are Autometer Phantom series)
o Trans temp 100-250 degrees F
o Pyrometer 0-1600 degrees F
- B&M hammer shifter
- Door pull strap trim pieces (missing from previous owner)
- Steering wheel – usable, in rough shape (previous owner)
- Horn trim ring broken (previous owner)
- Turbo 6 floor mats
- New floor mats (after market)
Exterior:
- Minor rock chips
- Minor door dings
o Previous owner left tire jack unsecured, which dinged the left rear quarter panel in 2 spots from the inside
- 5% limo window tint
- All original center caps for wheels
- All original emblems (in good shape)
- Hood mounted Autometer Phantom series fuel pressure gauge 0-80 PSI (I have a fuel pressure isolator, however it isn’t hooked up
I have the original GN wheels as well and if you pay close to asking price I will include a great working condition 69 Turbo 400 tranny that I was thinking about swapping into the car as well as a torque converter for it, I will include the MT ET street 26X11.50X15 drag radials (only have about 5 passes on them) and the correctly offset wheels fully mounted and balanced along with any other new or slightly used parts I have for the vehicle and a dual woofer box with two MTX 12" woofers (one was damaged by my cat while it was in the house however the other one is in great shape). My name is Andrew and you can reach me at (970-324-1124) text or call or email me at Carhartt17@comcast.net (I have a Blackberry with me at all times so I should be able to respond promptly. I am willing to drive sometime for delivery if a deal is made.
-Andrew
Why you selling ? Gotta pay off that honeymoon .. hahha? Looks like a sweet car.. you will get more interested members once you post the pics!
I decided to sell because I have had my fun with this car and would like to start another project. This car was really the one that started it all for me and it will be very hard to let it go but I would also love for someone else to enjoy this car as much as I have. Also we are staying on our honeymoon for one more day so I will put pics up on Tuesday.
-Andrew
Ok finally got the time to get some pictures up. Due to the condition of the paint I am going to lower the price to 22,500. I think some time with a clay bar and a buffer and it would look so much better I just don't have to time to do the work myself. Please let me know what you think and if this is a fair price or not.
Few more pictures.
Thanks! Duh I cant believe I missed the under hood pics.... Anyway here they are. It looks pretty plain jane but I am not really into chrome and sticking out. I like my cars as sleepers! Any other pics of the car you guys want? Underside, trunk, exhaust, tranny etc?
I am sure you have a lot of blood, sweat, and tears (including money) in that baby.
As with any of our cars we never get out of them what we put into them.
If your not strapped for cash just run it for a year or two and hopefully things turn around.
Pristine examples of low mile origional GN's are having a tough time fetching over 20k.
Pristine examples of TTA's and T's are having a tough time brining 13-15k.
I understand all the money you have spent, trust me I do but nobody ever seems willing to pay for all that on the back side.
I wish you the very best in your sale.
Ty
Ty
Thanks for the well wishes I really appreciate it. I knew when I bought the car that I would be in it over my head in cash but I kept throwing money at it :D haha. The market sucks right now for special interest vehicles which is too bad and I will probably end up taking your advice and just enjoying the car until the market gets a little better.
-Andrew
20,000 OBO must sell for financial reasons make me an offer I cant refuse. At this point I will have to say no trades please.
-Andrew
