.030 109 BLOCK,020 TURBO CRANK, BILLET MAINS ,TRW PPISTONS,W LIGHT WEIGHT PINS ,RJC GRIDEL,BALANCE ASSEMBLY,DURABOND CAM BEARINGS,MOLLY RINGS,FLAT TAPER CAM, GNI PORTED ALUMINUM HEADS, 70MM TB, 70M PHENOM,SCORPION ROCKER S,130 VALVE SPRINGS,CONETIC HEAD GASKETS,ARP HEAD STUDS,PT61 TURBO W 63HOUSING,PTE FRONT MOUNT INTER COLLER,ATR3 DOWN PIPE,KENNE BELL HEADERS,9 K&N FILTER,POLY 55LBS INJECTORS
DRIVER MOTOR MOUNT,LTI STARTER, CASOER GROUND, IGNITION PLASMA BOSTER, RJC VALVE COVERS,4 CORE RADIATOR,160THERMO,340WALBRO,KENNE BELL BOAST A PUMP TRANSMISSION 2004R,BUILT BYLONNIE DIERS IN CINCINATI ,PRECISION INDUSTRYS 9.5W 3600 STALL DEEP SHEET PAN,W REAR SUM,PB&MTRANS COLLER VACUM BRAKES KIRBAN SPRINGS BILSTEIN SHOCKS, REAR END3.42 GM LIMITED SLIP, BALANCEDDRIVESHAFTW HD U JOINTS INTERIOR IS GREATE HAVE HOOD GAS GUAGE ALL INTERIO GAGES ALLSO HAS AN ALKI KIT THAT I HAVENT INSTALLED YET,JUST PUT IN A ELECTRIC EXHAUST CUT OUT 19/9.5 WHEELS JVC MP3 CD PLAYER,FOSGATE AMPS 10INCH BAZUKAS I STOP COUNTING AFTER I REACHED 25K IVE INVESTED PAINT IS 8 OUT OF 10 VIEW PIC
WILL TRADE FOR A 1968 CAMARO MUST BE CLEAN
pugads650's photos and albums on webshots
