EightSecV6
MDBL
- Jul 18, 2001
We had a deal on this car but it has fallen through. I have for sale Barry Walkers backhalf rolling chassis for sale. This car has run low 8's at 170mph and built to withstand 1500hp. It is set up for a Buick V6 and turbo 400.The chassis has been NHRA certified down to 7.50, it has a fully tig welded chromoly cage and 2x3 framerails. The wheel well have been stretched (looks factory) and it has 17x33 tires on it with Weld wheels on the front and rear. Pro 4 link rear suspension with 1 5/8" bars (not the typical mail order 1" bars!), Strange rear double adjustable coil overs and wishbone track locater. Sheet metal rear end housing with Strange rear disc brakes , Strange 3rd member with 4.30 PRO gears and Strange 40 spline axles.Chromoly wheelie bars and Stroud chute with release handle and cable.Fiberglass deck lid with custom aluminum rear adjustable wing.Inside it has beautiful tinwork (wheel tubs etc) still has the GN dash (with NO trim) and a dummy instrument cluster. Window net and mounting,racing switch panel with fuses,Wilwood master cylinder with proportioning valve and Hurst roll control.Factory column and steering whell. The front crossmember has been trimmed down for weight reduction and clearance.Still has the factory firewall in the factory location and a manual steering box. The front suspension is basically stock. It includes BRAND NEW fiberglass doors that will need to be mounted and the fiberglass front end from my race car that will also need to be mounted.(the carbon fiber stuff in the pictures has a new home )and a fiberglass pin on hood.The car also has an 8 gallon fuel cell and dual battery mounts as well as a fiberglass rear bumper and charging lugs. There is $15000 in just chassis work in this car built by Gary Athey Racecars in Va. $7000 or best offer, will consider trades.
For pictures, check here!
http://www.t6p.com/forums/showthread.php?p=42007#post42007
Also includes chromoly driveshaft with yoke!
