86-87 Turbo-regal Gasket Sets; SAVE $95
Red Regal T
Senior Member
WHY ARE YOU PAYING MORE?
2 COMPOSITE TYPE HEAD GASKETS
.........appear identical to felpro head gaskets
1 CORK OIL PAN GASKET
2 CORK VALVE COVER GASKETS
1 NEOPRENE FRONT COVER SEAL
1 NEOPRENE REAR MAIN SEAL SET
1 O-RING FOR WATER OUTLET
6 VALVE STEM SEALS
7 FUEL INJECTOR O-RINGS
1 TIMING COVER GASKET
1 WATER PUMP GASKET
2 EXHAUST MANIFOLD GASKETS
1 OIL PICKUP SCREEN TO BLOCK GASKET
1 THROTTLE BODY TO PLENUM GASKET
1 UPPER PLENUM TO INTAKE MANIFOLD GASKET
1 VACUUM BLOCK GASKET
1 TURBO OIL RETURN GASKET
1 OIL PUMP GASKET
1 CAM SENSOR DRIVE O-RING
1 DRAIN PLUG NYLON WASHER
Don't forget, neoprene front and rear gaskets which cost over $25 anywhere................. ARE included.
AUTOZONE LISTING FOR EXACT SAME SET, SAME BRAND, HERE
SAVE A LOT !!!................................$115 includes shipping
6 VALVE STEM SEALS
1 WATER PUMP GASKET
1 OIL PUMP GASKET
AutoZone.com | Shopping | Zip Code Request
Click "Buy Online" beside the item you'd like to purchase from AutoZone.com.
Click "Add to Store List" beside the item you'd like to add to a shopping list that can be sent to and paid for at your preferred AutoZone store.
Full Gasket Set for a
1987 Buick Regal
Normal Stock
Special Order
Not Available
Item Part
No.
Warranty Core
Value Unit
Price Availability
Store Web
ROL FS33061 $179.99
Intake manifold, Hi-per blue valve cover gasket,
rubber timing cover seal and set, rubber rear main
bearing set not included
