'86-87 parts: engine/trans/body
gnx7
I'm into LSx stuff now so it is time for my GN stuff to go. (all parts are used and for '86-87 unless specified)
1984-85 style crank sensor (no mounting bracket) $15
1984-85 style transmission dipstick/tube (red handle) $20
These parts below are all '86-87 style!
Engine parts:
*new* TA performance Adj Oil Pressure Reg pn TA 1502 $20 shipped
Bosch FPR 237 $20
Bosch FPR 233 $20
Bosch FPR 233 with billet adj top $30
(6) Red Top injectors p/n 280150756 (1 pintel cap broken, a few 0rings missing) $50 Cody Motorsports will rebuild/clean/flow them for $80!
(6) Stock GN injectors $30 Cody Motorsports will rebuild/clean/flow for $80
ported stock GN upper doghouse (intake) 62mm with EGR tower removed $30
TB cable bracket holder $25
stock GN turbo cast iron downpipe elbow/puck/gasket/stock downpipe 2" stub $30
stock intercooler uppipe (painted black) with HKS blowoff valve welded on $40
(2) alum accessory brackets $40 each
powersteering pump/pulley with high pressure line $30
*new* GN charcoil canister $20
*new* ARP complete exterior engine bolt kit for a "show look" (valve cover/front cover/intake/etc. 55 bolts stainless and 6-8 black oxide style total (they all are individually bagged in groups and have p/n written on them; however I don't have a list of where they go.... that is why they are soo cheap) $80
crank pulley with stock crank spacer $20 (painted red)
Turbonetics DeltaGate Mark II pn 10101 (needs new diaphragm) $25
(4) '84-85 style valvecovers (ribbed) with no holes (meaning no provision for filler neck or breather of any kind) $5 each (need painting)
(2) '86-87 style valvecovers (ribber) with fill neck hole $5 each (need painting)
stock bare throttlebody (no sensors; however has blade/shaft) $20
(3) stock fuel rails $25 each
(1) GM front engine cover (no wear in cam bearing/retainer area at all) $60 (essentially brand new)
(2) used front engine covers minimal cam bearing/retainer area wear $25 each
Engine Electronics/wiring:
*new* Wells TPS sensor $30
*new* Caspers Electronics 14 guage injector harness $80
Caspers Electronics 02 simulator (remove stock O2 sensor when running leaded fuel) $10
crank sensor with bracket $20
(2) ESSC sensor (pn HKP 881654) black square shaped w/ 5 blade prongs $30/each
(26) misc chips: ATR, Kenne Bell, Delco, Red Armstrong, Jay Carter $100 for all (will not separate)
Transmission and rear end parts:
TH200-4R oil pan with drain plug welded in (on very bottom) $20
B&M Megashifter for TH200-4R with 3' cable $60
Art Carr (the real one) TH350 8" 4500 stall convertor (Art Carr retail $1200.... and freshly rebuilt & restalled with receipt zero miles) $800
12 bolt chrome Trans-Dapt rear diff cover pn 9584 (fits '65-70 Intermediates and 70-71 Camaro and Chevelle 12 bolt rear with filler plug $15
10 bolt Mr. Gasket ring gear spacer with bolts pn 908A $10
Body:
Passenger side (RH) turn blinker (orange rear/clear front curved) pn 65023521 $10
Driver side front GM bumper filler $20 (needs paint but in good condition)
black GN antennae with motor/harness/plug complete $20 SOLD
*new* mint condition in original packaging Bowling Green Customs '84-87 Regal/GN protective bra $60
aluminum front bumper reinforcement (the 5+ foot long piece) $70
Shipping extra unless specified.
gnx7@hotmail.com for pics if you need them. Please state which pics you want!
Thanks,
-Mark
I will take the antennae .. Send me your payapl address and shipping cost to Davie Florida 33325
put me in line for adj regulator, front aluminum support, and if the blinker/park lens is the one that goes in the bezel and is black trim and not chrome. PM price shipped.
Blinker is the black style and sold to TLimited.
Apparently the near new front cover is not OEM GM. Someone PMd me and said if the front crank seal is installed from the front it is made in China. Installed from the rear means GM. It is in mint condition however.
pics of Deltagate and oil pan. Other pics to follow.
Antennae SOLD
Both Driver's side valvecovers sold
turn blinker sold
alum bumper support/adj FPR pending
both alum accessory brackets SOLD
chips SOLD
DeltaGate pending (getting shipping quote for you Kid Turbine)
Precizion818- pics go out today of adj FPR/p/s pump/bolt kit
All others with pic requests sending pics out later today.
I'll take this please. PM me shipping cost and paypal address. Zip is 35976.
Thanks! :)
update 9/4/08 Disregard posts above... some people flaked so an accurate listing is below
Engine parts:
Bosch FPR 237 $20
Bosch FPR 233 $20
Bosch FPR 233 with billet adj top $35 SOLD
(6) Red Top injectors p/n 280150756 (1 pintel cap broken, a few 0rings missing) $50 Cody Motorsports will rebuild/clean/flow them for $80! pending
(6) Stock GN injectors $30 Cody Motorsports will rebuild/clean/flow for $80 pending
ported stock GN upper doghouse (intake) 62mm with EGR tower removed $30 SOLD
TB cable bracket holder $20
Turbonetics DeltaGate Mark II pn 10101 (needs new diaphragm) SOLD
(2) '86-87 style valvecovers (ribber) with fill neck hole SOLD
stock bare throttlebody (no sensors; however has blade/shaft) $20 pending
(1) front ('86-87 style) engine cover (no wear in cam bearing/retainer area at all) $60 (essentially brand new)
(1) used ('84-85 style) front engine cover minimal cam bearing/retainer area wear $25
*new* Caspers Electronics 14 guage injector harness $80 pending
Caspers Electronics 02 simulator (remove stock O2 sensor when running leaded fuel) SOLD
(26) misc chips: ATR, Kenne Bell, Delco, Red Armstrong, Jay Carter SOLD
TH200-4R oil pan with drain plug welded in (on very bottom) SOLD
B&M Megashifter for TH200-4R with 3' cable SOLD
Body:
Passenger side (RH) turn blinker (orange rear/clear front curved) pn 65023521 SOLD
Driver side front GM bumper filler SOLD (needs paint but in good condition)
black GN antennae with motor/harness/plug complete SOLD
aluminum front bumper reinforcement (the 5+ foot long piece) $70 pending
Thanks,
-Mark
This includes the bov correct? can i get some pics and shipping to 91601?
thanks dennis
HI Mark, I got your package today but you forgot to send me a fuel rail. I received both valve covers and the o2 simulator but no fuel rail. Send me a PM if you need my address again.
alum bumper support boxed up/weighed ready to ship
fuel rail sent out... .whoops my bad! :eek:
update 9/8/08 Disregard posts above... some people flaked so an accurate listing is below
Engine parts:
Bosch FPR 237 $20
Bosch FPR 233 $20
(6) Red Top injectors p/n 280150756 (1 pintel cap broken, a few 0rings missing) $50 Cody Motorsports will rebuild/clean/flow them for $80! SOLD
(6) Stock GN injectors $30 Cody Motorsports will rebuild/clean/flow for $80 SOLD
(2) alum accessory brackets $40 each SOLD
powersteering pump/pulley with high pressure line $30 SOLD
*new* ARP complete exterior engine bolt kit for a "show look" (valve cover/front cover/intake/etc. 55 bolts stainless and 6-8 black oxide style total (they all are individually bagged in groups and have p/n written on them; however I don't have a list of where they go.... that is why they are soo cheap) $80 SOLD
(2) '86-87 style valvecovers (ribbed) with fill neck hole SOLD
stock bare throttlebody (no sensors; however has blade/shaft) $20 SOLD
(2) stock fuel rails $25 each
Body:
Thanks,
-Mark
Still tons of stuff left.....
Charcoal canister sold and 1 pair of '84-85 valvecovers
