hi guys i picked up a 85 gn (we2) about a month ago which had been parked for 5 years
the body is in descent condition with some small rust on the door corner and driv quarter as well as some slight damage to the same
the interior is all original and in nice shape so not much to do other than gauges and cleanup
now the engine is all stock but when it was running its smoked profusely out of the rusty exhaust, made squeaking, grinding, clattering noises from within and the tranny slipped badly,
i picked up a used 87 turbo and installed and that cured to smoking caused by the original badly worn turbo,
pulled the motor out this weekend and found 3 collapsed lifters, 2 head gaskets showing blow by, and 4 badly spun bearings along with alot of metal shavings in the pan,
needless to say i'm in for a rebuild which is where the advice is gonna come in handy
the car had fairly low miles and the piston bores look good so far but if the machine shop says i need to bore then am i best to go forged or hyper pistons?
any special bearings and rings to consider?
i will clean up the oil and water holes on the block and port the heads/intake myself, is there a link to the best secrets for this motor? i hear alot of people saying it cant be treated like a regular motor and need tight clearances
i have a spare 1983 carbed gn motor i picked up for parts is the crank the same if my original cant be saved?
are the cometic gaskets the best choice? thats what i used when i turboed my charger .
i have a intake from an 87 on the way as well as 60lb injectors, 87 ecm, double roller chain, and plan on alky injection as well as adjustable fuel reg, bov, larger tb and maf, translator, tt chip, cold air intake and all the usual gauges, pypes exhaust
sorry for the long first post but i'm exited to get it done
thanks jason
thanks jason
