Absolutely! Plus they are "Valved" specifically for the springs rate, Timing of the jounce bumpers. Together they work fantastic!Scot,
Do your replacement shocks work specifically with the 2" drop springs , meaning have the length of the shocks been modded for the shorter travel?
scot w. said:Absolutely! Plus they are "Valved" specifically for the springs rate, Timing of the jounce bumpers. Together they work fantastic!
Very good point on the shock travel! If you lower you car 1"-2" and then put on regular (off the shelf) billstein shocks or something, you just shortened your shock travel the same as what the car was lowered.
Here is just one of our customers who love the ride quality and handling of the DSE 2" drop spring & shock combo http://www.turbobuick.com/forums/threads/good-guys-autocross-fort-worth-tx.373501/Can't wait to get mine installed!
Charlie wha kind of issues do these cause? On a driver not auto cross car?Dropped spindles will cause more issues than doing it with a 1" drop spring and tall lower ball joints. You can get 1" taller ball joints and a 1" drop spring which will give you a 2" drop in the front and then go with a 1" drop in the back which will give you a bit of a rake and help the handling some.
Bump steer issues and in some casses wheel clearence issues.Charlie wha kind of issues do these cause? On a driver not auto cross car?
