I'll take some pictures of my "junk" for you...
View attachment 30563[/ATTACH]
As you can see, my motor is junk just as the above @ss had described.
Came freshly rebuilt and looks BRAND NEW and I paid $2500 for it.
With paperwork.
Well you got a screaming deal because good cores are upwards of $1500. Good running used ones with unknown miles are $2000k+
I just rebuilt the one our Monte (109 block, Wisecos, Eagle crank and h beams, balanced, assembled, roller cam, steel caps, new GM timing cover & oil pump and it was almost $5500.
As far as a trans went, I could have gotten a newly built STOCK unit for $750, again, with but knew I was going to throw some more power to it later so had a 10 sec capable billet trans made for me. That, with the 9.5" 3200 stall lockup converter BRAND NEW was $2100.
Again, $750 is very light for a rebuild on a 2004r by someone who knows what they are doing is almost a prerequisite for these cars as even a stock engine will over tax a stock trans. The one in our car was done with the critical billet parts by Eric Schertz at Dynotech and was approx $2k plus the 9x11 from Bruce which was another $800. Again, not cutting corners. On a side note when I first did the swap I used the original 44k mile CZF Monte trans and smoked it with a stock engine in less than 1500 miles.
Then I got a PERFECT front mount intercooler for $400 with all piping and couplers and clamps.
Again you got a smokin deal that doesnt happen everyday.
All in all I probably with EVERYTHING down to every last nut, bolt, and washer have $5500-6000 in it. And thats with the BUILT trans... if I went with the stocker, I would have saved another $1300, putting my total around $4200-4700!!
Sounds a little light to me when you take into consideration other essentials such as radiator, fan, hoses, fuel lines, tank, pump, frame mounts, drive shaft, trans crossmember, rear, exhaust system, down pipe, vacuum pod for the vaccum booster (OR conversion to Power master or hydro boost) and then all the other nickle and dime items such as relays, wiring connectors, battery cables. I am sure I am forgetting a bunch of things, but I know I have an over stuffed envelope here of receipts for all the things I bought. If I had to do it over, I would have bought a parts car as I have come across plenty for under $4k that I could have swapped everything intact from.
6 years ago, this site probably didnt exist, and if it did, it didnt have hardly any knowledgeable helpful people on it, compare to NOW. And your methods of obtaining this sort of stuff was nearly IMPOSSIBLE.
This site has been around since the mid 90's. I believe it originally started circa 1997-98. I have been a member since 99 which was before the original board crashed in 2001 and lost everything. I bought many items for both of my cars from people on this board as well as locally. Back when I did my swap, no one else had attempted it (or atleast posted that they did). A close friend of mine named Dan Goldstein helped me repin the C100 block so that I could hook the stock engine harness to it. He had wrote and published an article on how to do the wiring swap back when he owned Gbody.org. Our Monte has a complete stock Monte harness from the firewall back with only the additions of some wires to the ALDL connector and another IP connector under the glove box.
Running around junkyards and talking to morons that had them advertised in the paper. Things have CHANGED.
Done with my rant.
ANYWAY... as mentioned, I can help you out. Email me with questions.
Dont listen to these guys that tell you to go buy a GN unless you really prefer a GN over a monte.
A nice one that isnt "junk" will cost you $12K-$15K all day long.
